old homelite xl bar oiler problem
Old 10-17-08, 04:48 PM
my xl is about 25 yrs old, runs like new, but the oiler which is activated by a manual pushing of a plunger, will not push any oil onto the bar.
Old 10-17-08, 10:26 PM
cheese's Avatar
Received 45 Votes on 40 Posts
I'm not overly familiar with the oiler on that saw, but I would suspect the seals on the plunger are worn or missing.
Old 10-17-08, 11:48 PM
G
When you remove the cover plate that covers the clutch, it will expose the port that aligns with a slot in the bar through which the oil is pumped.
Sometimes dirt & saw dust plug this port. With the chain & bar removed you should be able to see oil expelled from this port while pumping, provided the tank has oil & the pump is working.
John 3:16
Old 10-18-08, 06:12 AM
Yeah I agree on checking the oil slot (hole) in the bar first. If this is opened up then I'd go with the oiler as being the problem. Later!
