Source for MTD obsolete parts?
Old 10-20-08, 12:29 PM
I
Anyone have a source for MTD obsolete parts? I have here a SnowChief SC8250F snowblower that needs wheel bushings.
The part number is 707828. I called MTD and the part was discontinued in 2004.
Thanks.
Old 10-20-08, 05:38 PM
F
if you can determine the ID and OD your local hardware store may have some bronze bushings that would work. you might have to cut them for length.
Old 10-20-08, 07:57 PM
A
Received 3 Votes on 3 Posts
Bearing
Is the bearing a hex outer 7/8" on the flats and 3/4" ID? If so there are after market parts Stens 225-763, Rotary 8783, Laser 95471 the Stens & Rotary parts are oil impregnated iron the laser part is bronze
AJ
Old 10-23-08, 09:04 AM
A
Bearing?
Indypower was this the bearing that you needed?
AJ
Old 10-23-08, 09:57 AM
I
Thanks AJ. The 8783 is a perfect fit. Rotary should list that as fitting this MTD also. They would get more sales if they did.
Old 10-24-08, 06:22 PM
A
MTD bearing
Thanks Indypower I'll pass the cross on to Rotary.
AJ
