Strange spark pattern on briggs 20hp engine
jl66redcpe's Avatar
NJ
10-22-08, 01:04 PM   #1
It is a 461707 0145 E3 engine. It wont start after it runs for 30 minutes or so. It seems to be getting fuel. I hooked my timing light up to the driver side plug and it seemed fine. I then hooked the timing light up to the passenger side plug and was surprised to see that it took several complete revolutions (5-6 or more) before spark appeared on that side. This just seemed like too many revolutions. I would think the coil on that side may be weak or bad ??
cheese's Avatar
GA
10-23-08, 01:18 AM   #2
Both plugs fire from the same coil. Coil failure is quite common on that engine, and I would change it. You have classic symptoms of a bad coil. Don't buy an aftermarket coil. They don't last long, sometimes bad out of the box, and many places don't take returns on electrical parts. Use a briggs coil... runs around $55.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
bontai Joe's Avatar
PA
10-23-08, 09:25 AM   #3
Also check the plug wires, although it is probably the coil.
