Briggs carb problems
Old 10-28-08, 04:01 PM
T
I just bought a used yard vacuum from my neighbor with a Briggs 8hp I/C engine on it (model 195432). It has been sitting a long time but he did drain the gas out of it. I finally got it started with new gas but you have to keep on choking it to keep it running. The gas line seems to be clear. I know this is probably a question that has been asked before but I am new to this forum and could not find it. Can anyone tell me what to do about this problem?
Thanks in Advance,
Tom
Old 10-28-08, 05:51 PM
You will have to remove carb and thoroughly clean. Please post the type number off of the engine, it is right next to the model #. We can then give you the correct carb kit to buy for the job
Old 10-29-08, 05:06 PM
T
I appreciate your responce - smallengineguy
Will I need a kit or can I just take it apart and clean it good?
The model # is 195432
The type # is 401301
The code # is 91112110
Old 10-30-08, 01:56 AM
cheese's Avatar
You might be able to clean it and reassemble, depending on the condition of the carb and parts. Take it apart and see what there is to see...go from there. If the bowl is full of crud, the gaskets are torn/worn, and the needle is stuck, go ahead and plan on getting the kit.
