Fuel Line
Old 10-31-08, 07:10 PM
Question Fuel Line
This probably have been mention before.I have been using tygon fuel line for several years,now when I use it in 2 cycle engines,it seems to shrink,and start leaking where the fuel lines comes out of the fuel tank.I use the 3/16O.D.and I.D.3/32after about 6 mo.Someone mention using stihl fuel line the black tubing.I check with the stihl dealer in my area,they use tygon also.The dealer said it was the ethonol in the gas,What I need is the size of the stihl fuel line that is a little bigger,or what do ya'll use.
Thanks,
Jerry
Old 10-31-08, 09:13 PM
G
Received 30 Upvotes on 29 Posts
The post was probably me.
Stihl and some others use rubber(looks like rubber) fuel line rather than the clear plastic or other yellow stuff. My local guy told me the rubber line normally comes in .5mm but that Stihl branded fuel line is .6mm, since I had a leak try Stihl. It worked for me. He also said the yellow stuff lasts longer than the clear but always ends up leaking. Just his observation, he said. Hope this helps. Have a good one. Geo
Old 11-01-08, 09:45 AM
Thanks,geogrubb for the info.
Jerry
