2 cycle carb mystery Solved
Chuck1936's Avatar
11-01-08, 10:38 PM   #1
On 10/20 I posted about problems with the carb on an Toro S 200 sno blower I bought used. I found there is a check valve behind the intake tube and that this is what was causing the flooding problem. It is very small and is pressed into a pocket and after removing the inlet tube, I had to remove it using a Bridgeport mill after all other methods failed. After aligning the carb body in a vise, I indicated the bore of the inlet tube, then used a 3/16 end mill to move on XY coordinates to within .005 of the edge of the valve pocket bore. I used a hardened pick to collapse the remaining valve body and pulled it out.
After putting in the new check valve and new inlet tube the problem was solved; getting the inlet tube out of the carb body was not easy, had to use a vise to clamp on to it, thats why the new inlet tube.
j HOWARD's Avatar
MI
11-02-08, 05:42 AM   #2
That's an interesting way to save $80......................
