i need help disassembling a coleman powermate generator
Old 11-02-08, 10:01 AM
F
i bought this generator thinking that the generator part would detatch from the motor because i want to use the motor on my minibike or build a gocart but after exposing the shaft i cant figure out how to take of the part of the generator that spins on the shaft between the coils of copper on the outside i am not very experienced with engines and i hope i dont sound too ignorant any help would be great thanks, josh.
Old 11-02-08, 12:10 PM
31YTech's Avatar
Josh,
If the generator 'Rotor" is junk just loosen/remove the long center bolt then smack the side of it with a good sized hammer, This will pop it loose from the crankshaft.
But, Your going to find a tapered crankshaft in that engine and no way to install a centrifugal clutch for what you want to put it on.
