Ariens Zero Turn Sarting problems
Old 11-03-08, 08:31 AM
I
Have an Ariens Zero Turn Zoom 1844 Model #915037-00015 Briggs engine #31H777-0110-E1. Now that the cold is creeping in here(30 degress her in the AM), it does not want to turn over fast enough to start in the morning. Had a new starter put in last summer, just replaced the battery with a 430cca rating, oil changed this spring using the recomended SAE30. When the outside temp gets close to 50 for a couple hours, it will start, but the starter still turns slower than normal. After running for 30 mins, it will start right up.
Thanks.
Old 11-03-08, 09:02 AM
31YTech's Avatar
Indy,
It may be right at the point the valves need adjusting with the added cooler thicker oil. Everything else appears to be in order, For the amount of time it takes I would check them.
Good Luck
