Honda ht-r 3009 lawn tractor
Old 11-06-08, 02:09 PM
V
I'm having carburator problems with this machine.
It needs to be removed.when i slide it off its studs the bowl interfers with the frame.
Can the long studs be removed, are they preesed in ??
What are my alternatives ?? Thank you
Old 11-06-08, 06:52 PM
31YTech's Avatar
Use two nuts screwed onto the stud and tightened (jammed) together then screw the studs out using a wrench on the inner nut. Re-install in reverse order tightening with the outer nut.
Good Luck
