Ariens B&S engine spitting oil
indypower's Avatar
NH
11-07-08, 02:09 PM   #1
Ariens Zero-Turn Ariens#915037-00015 B&S engine#31H777-0110-E1 spitting oil from feul pump impusle hose. The impulse hose is attatched from the pump to the oil filler tube. Took off the hose and it was full of oil. Would this be caused by a dirty breather? Oil was just changed to 5-w30 per owners manual when using under 40 degrees.
geogrubb's Avatar
MO
11-07-08, 03:17 PM   #2
Sounds like it may have been over filled during the oil change. Have a good one. Geo
indypower's Avatar
NH
11-14-08, 01:21 PM   #3
Problem solved!!
The Ariens problem has been solved. Customer had changed oil to 5W30 synthetic from SAE30HD convential oil. The synthetic is so thin that it will flow easily thru any hose that has any amount of suction. This would not have been a problem if the engine wasn't quite so old (its a 2002 model) and had so much time on it with the SAE30 oil. Hour meter shows 365 hours. Customer bought it used. Hour meter could have been disconected or not been working before he got it.
Moral of the story: Do NOT change to synthetic oil if the engine is more than 2 years old!
cheese's Avatar
GA
11-14-08, 08:43 PM   #4
I think the %w part is where the problem is. Synthetic oil works well in most engines no matter how old they are, but if you choose oil that is too thin, you'll have problems even in new engines.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
