Craftsman motor died
Old 11-10-08, 01:27 PM
I have a Craftsman 4.5HP Lawn Vacuum that just died. It started to slow and died. Ran at slowest speed but rough now not even that. I'm thinking clogged fuel line since the spark plug looks clean. How do I get at the fuel system to clean it? Any suggestions?
Old 11-10-08, 01:29 PM
I
Please post model number & engine number
Old 11-10-08, 02:35 PM
info
Motor model 143.01 4500
Engine Family: YTPXS 1951BB
Sears Craftsman Lawn Vacuum
4.5 Horse Power Model number 247-770110
24B031E099
This is all the info I could find
Old 11-10-08, 04:27 PM
G
A suggestion.
Clamp off the fuel line, remove the carb bowl, release the clamp to see if you have good fuel flow to the carb, raise the float to see that it shuts off the flow with minimal pressure, clean the junk from the bowl, clean the bowl nut, 2 holes close to the bottom and a tiny one about midway up(I usually use the wire from a twist tie), spray all holes, cracks and crevases with brake parts cleaner, reassemble(be very careful with the bowl gasket) and you should be good to go. If this didn't work it will be probably be necessary to rebuild the carb. If I missed something one of the real mechanics will post to help further. Refer to the photo below. Have a good one . Geo
http://i190.photobucket.com/albums/z...c_bowl_nut.jpg
Old 11-14-08, 08:44 AM
Your suggestions worked great. Motor is back 100% Had a tank of bad gas. Thanks very much for the help.
