Tecumseh 12 hp OHV- starter spining ???
Old 11-12-08, 05:30 PM
R
Have a creaftsman riding mower with a Tecumseh 143.286162
12 hp OHV engine.
Starter will spin but won't engage the flywheel. Starter is 36680-CCRotation
battery is good, stater is clean, connection clean.
Can a starter just go weak?
Old 11-12-08, 09:01 PM
cheese's Avatar
The starter may just need cleaning around the bendix drive area. Sometimes it just accumulates crud and dust under the drive gear and makes it stick.
One other thing that could cause it is if it is rotating backwards (battery connected backwards).
Old 11-13-08, 08:00 AM
R
put a new bendix on and battery is correct, it spins but will not engage the flywheel, won't pop up unless i squeese the rubber bendix?
Old 11-13-08, 10:50 PM
cheese's Avatar
Then the threaded section of the armature drive end is dirty, rusty, or gummed up, etc...
Old 11-14-08, 02:26 PM
R
Ordered a new starter 158.00 big ones. So, here I am looking at the old one. Have nothing to loose and rip it apart. I Clean the contacts and wire harness and magnets, notice a wire on negative side of the contacts loose - fix it - put it all together and BINGO the starter runs like a champ.
Old 11-14-08, 09:41 PM
cheese's Avatar
Ok, apparently the starter must have been turning really slow and didn't have the inertia force to spin the bendix upwards. Too late to cancel the order?
Old 11-15-08, 12:47 PM
R
order cancelled, good to go
Old 11-15-08, 07:42 PM
cheese's Avatar
Good job! Thanks for the update!
