B&S idle problem
Floydyisms's Avatar
11-13-08, 11:17 AM   #1
B&S idle problem
I have a 19.5 horse B&s model no. 42E707 on a craftsman mower. It starts fine but will run, idle down to almost stall, run, idle down to almost stall repeatedly, worse when in gear. I have put on a new air filter, and fuel filter but no good, could this simply be old gas? or do I need to dive into the carb??
Thanks
marbobj's Avatar
IA
11-13-08, 06:48 PM   #2
That surging problem is normally a lean fuel/air mixture = dirty carb. Could be attributed to old gas. Changing the gas would be a good place to start.
tater1800's Avatar
AL
11-13-08, 07:17 PM   #3
See the other Briggs thread. I think you both have the same problem.
cheese's Avatar
GA
11-13-08, 09:39 PM   #4
Open up the carb, clean it well, remove the main jet and clean it and the area behind it, and your problem should be solved.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
