b&s blowing white smoke
Old 11-20-08, 04:12 PM
I have a yardmachine with a B&S 28T707 engine and a walbro LMT carb. It is running pretty good but every few minutes blows a puff of white smoke. It has an idle mixture screw and it is set at 1 1/4 turns out from seated. What adjustments should I make? Thanks for your help.
Old 11-20-08, 04:23 PM
30yearTech's Avatar
Gray, White or Bluish smoke pretty much indicates oil being burned in the engine. Check the oil level in the engine to make sure it's not overfull and if it is, check and see if the oil smells of gas. If gas has contaminated the oil, then in addition to needing an oil change, you most likely have a problem with the carburetor as well (but more then an adjustment will fix)
Old 11-20-08, 05:48 PM
I checked the oil and it looks fine, level ok and does not smell like gas.
Could it be rings or something?
Old 11-20-08, 06:49 PM
B
In my experience, I would say it would most likley be valve seals. I have had lots of engines that do that and the rings are usually fine, the valve seals weap a little each time the valve is activated and the extra oil eventually runs into the cylinder. But don't quote me on that.
Old 11-20-08, 10:31 PM
P
How old (how many hours)? Based on my experience with a very similar B&S engine (28N707) Id bet you have a blown head gasket. Other than the smoke, my engine had been running fine and even checked out with a compression test (but ultimately failed a leak down test). Easy fix.
Some pix here of the head gasket repair here (although the engine eventually died due to other causes):
http://www.cardomain.com/ride/773108/2
Paul
Old 11-21-08, 04:08 PM
cheese's Avatar
I agree on the head gasket. I've never seen valve seals cause any problems on a small engine.
