Toro 2400 Snowblower Problem
Old 11-21-08, 02:32 PM
I have a Toro 2400 that will start with no problems and will run for a short bit of time before it dies. After it dies I will thry to restart it but the recoil pull start is impossible to pull out. After it cools down a bit it will alow me to pull the recoil and it will start again but repeats the same process. Any ideas?
Old 11-21-08, 03:28 PM
Have you been mixing the proper oil to fuel ratio? It sounds like the engine could be seizing = too little oil in the mix. Another possibility would be the compression release, but since it starts well the first time, then dies, I would check the fuel/oil mix.
