snow blower linkage HELP
Old 11-23-08, 10:58 AM
E
I have a Sears snow blower Model 247.88664 I took the carb off & cleaned it & all ready to go BUT I cant seem to hook up the linkage no matter how hard I try I bet I tried at least two hrs or more I dont give up easy but I finaly had to walk away. It has springs on which I did not fool with the rod with the 2 z bends I dont know which holes they go in & should the leaver be up or down or closed I though I tried every combo
ANY HELP PLEASE
Old 11-23-08, 01:43 PM
do you have an engine number, cannot get to engine with the model number
Old 11-23-08, 02:15 PM
E
its a Tecumseh where is the engine model #
Old 11-23-08, 02:33 PM
Stamped into the engine shroud, near the spark pug. If you have electric start it could be under recepticle. If not there on a tag on the side on the carb side.
Old 11-23-08, 04:03 PM
E
I found it the engine model # 143.025001
Old 11-24-08, 12:55 PM
E
also these #'s are on there if it helps
Engine Family YTPXS.1951BF
DOM 1165W
model # 143.025001
Old 11-24-08, 06:03 PM
Do these pics help? If you are unsure of what hole the linkage came out of, look closely often the one used will show some wear and be a little eggshaped.
Old 11-24-08, 06:51 PM
E
that looks like my set up but when I hook it up & move the gas lever up or down nothing moves the spring holds the one arm in one direction I dont see any other spring & I only took off the one linkage with the 2 z bends to take off the carb what am I missing thanks for all your help btw
Old 11-25-08, 04:29 AM
You will not see anything actually "move" when lifting throttle control. What you will find is when throttle is in slow/off position governor arm will move with little,no resistance. When you move to full throttle arm will be tight and spring back
Old 11-25-08, 07:54 AM
E
Well I hooked up everthing & still wont run it runs if I take out plug & put a couple drops of gas. Nows heres another question going to the carb is the gas line gas flows free no prolbem on the other side a smaller hose its going to primber bulb I felt air comeing from the out side of the carb the bulb does not seem to get hard when primeing the hose is on the carb & the other end is at the priming bulb can this be the prolbem.
Old 11-25-08, 11:06 AM
When you put the carb back together didi you adust the high speed needle on the bottom and the idle circuit needle on the side?
The bottom should be turned all the way in until it sets and then backed out 1 1/2 turns, the side needle 1 turn out.
Old 11-25-08, 02:14 PM
E
Well I finally got it running Beer 4U2 I took it all apart again & hooked it all back up & its running Im glad I found this site & thanks for all your help,now let it snow Im ready
Old 11-25-08, 03:12 PM
Glad it worked out for you. Have a great holiday.
Old 12-02-08, 02:17 PM
5
Tec 8 hp Ariens May Be close
THIS may help if they are similar .
