IN
11-24-08, 11:22 PM
Carb trouble
Hi all,
I bought a Craftsman all wheel steer lawn mower this weekend.
Got it cheap, so theres always a catch. Someone has put a different carb on it. It has a primer bulb like you would find on a push mower. It has the linkage, so it came with a different carb from the factory. It has a Briggs 12.5 hp engine.
As long as I push the bulb primer, it will run. My question is, is this carb. not big enough for this mower or could the carb just need cleaned?
Thank you
Thank you
IN
11-25-08, 11:55 PM
Tractor model number is 536.255860. The engine number is 143.436092 Ser# 3074D. Those are the only numbers I found on the engine.
Thanks
Thanks
GA
11-26-08, 12:20 AM
That's a tecumseh engine, and it sounds to me like someone managed to put a push mower carb on a riding mower engine???! Forget about trying to make that work...sounds like you're going to need a donor engine for parts. Who knows what else is messed up if someone went and did something like that...
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
