toro snowblower problems
Old 12-01-08, 07:37 PM
i have inherited an old Toro snowblower and am trying to get it up and workking
Model # 38040 serial# 9011159
i believe it is a 5hp Tecumseh
Starts right up but will not run without full choke on
I took the inlet valve? ( the one on the bottom of the bowl)
and cleaned both the bottom and top holes out with a thin wire and then sprayed them out with carb cleaner
Still have the same probelm
Whats my next step
Is a rebuild kit easy to do?
Also noticed that while it is running in the Garage (heated or at least not as cold as outside tonight(29 degrees) I put it in drive and as soon as it gets outside it dies
looking at repair manuals i notice my machine does not have a heater box over the carb. Is the heater box necessary?
any Help would be appreciated Winter is here!
Old 12-02-08, 05:05 AM
Sounds like you need to soak the carb, then blow out ALL holes with compressed air.
And yes, you do need the heater box.
Old 12-02-08, 09:23 AM
Thanks for the info
Before soaking the carb does anything have to be removed?
i.e. float bowl etc...
Old 12-02-08, 10:47 AM
[QUOTE=jmc1964;1474667]Thanks for the info
i.e. float bowl etc...[/QUOTE
Go to Toro website--homeowners--parts--type in your model #
pick serial #---pick your carb..........
Get rebuild kit-------follow instructions............
Get heater box................
