Please help me get this snowblower auger pulley off!
Old 12-05-08, 12:39 PM
Question for you, indypower, if you're still checking this thread...
Since my gearbox has some oil/grease coming out of where the shaft meets the gearbox, do you think I should now break down the gearbox and put a new seal in there?
I assume this is from the abuse the shaft took when I was trying to remove the pulley.
Or should I just make sure that the oil level is good and "run it".
(I'm worried about water getting in there).
Old 12-06-08, 08:27 AM
there's thick grease in my gearbox
maybe the grease or oil is too thin in yours,
maybe you should drain it and add new grease
the gearbox diagram doesn't show a rear seal just on the sides of the auger shaft
i,m to go ahead and replace the two seals and gasket and clean it since i have it out of the assembly
once i put this back together, i never want to take it apart again
hopfully indypower will answer soon
  #43
Old 12-07-08, 04:05 PM
Well I've decided to leave it be for now.
I painted the augers and impeller and housing tonight. I found out that Rustoleum's Dark Hunter Green is still not dark enough to match the blower.
Doesn't matter to you though, considering your new paintjob!
Tomorrow all that I have left to do is pick up some bolts and pushwashers... and then wait for the overpriced Sears parts to come in.
