AYP/Poulan/Hydro Gear
Dewdrops MI's Avatar
12-08-08, 11:53 AM   #1
I rebuilt my transaxle Mod. #150071.
How much gear lube and what type do I need to fill this unit?
cheese's Avatar
GA
12-09-08, 11:17 PM   #2
Use 20w-50 oil in the pump. I suggest using synthetic. I believe it will hold just over 2 quarts if I remember right. Use "00" grease in the gearcase. It should be available at a lawnmower repair shop.
Here's a manual: http://www.odref.com/pdf/Hydrogear/150071.pdf
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
12-27-08, 08:21 AM   #3
Posted By: cheese Use 20w-50 oil in the pump. I suggest using synthetic. I believe it will hold just over 2 quarts if I remember right. Use "00" grease in the gearcase. It should be available at a lawnmower repair shop.
Hi Cheese,
I only replaced the ring gear and cleaned out the old gear lube. Is there a way to check lube level in the differential?
