12.5 murray wont start
A friend gave me a 12.5 40" murray riding mower ,so i got it home and started looking at it to see if i could get it to run. i got it to turn over but it will not start it is like there is no spark or fuel all it does is turn over if any body could help me or tell me what could be wrong thanks
Check the battery make sure you got 12 volts. Sense it turns over pull the sparkplug with it still in the boot and hold it to the engine block and crank the engine(use rubber gloves or rubber handled pliers to prevent shock). Do you see spark at the plug. If so then its not getting fuel. Put a teaspoon of gas in the sparkplug hole and install the plug. Crank the engine. If it fires or runs for a second or so then the carb needs cleaning or rebuilding.
