can't pull cord on chainsaw all the way out
amissville611's Avatar
12-12-08, 09:45 AM   #1
I have a model 3500 poulan chainsaw and when I pull the staring cord it kicks back when it only a short way out..like the engine is fireing befor the piston reaches TDS. its really a violent kickback..I followed all the instructions for the starting the saw ..any suggestions..Thank you for your time
marbobj's Avatar
IA
12-12-08, 09:58 AM   #2
Take off the pull starter, remove the flywheel, and check the key for proper alignment on the crank. Those things have the little cheap flywheel key molded into the flywheel. It sounds like yours may have stripped the key and the timing is slightly advanced.
indypower's Avatar
NH
12-12-08, 10:59 AM   #3
You need flywheel key part #530032093
12-12-08, 02:23 PM   #4
chainsaw problem
Thanks for your quick response--
it looks like it will be a lot easier than I thought Thanks again Mike
cheese's Avatar
GA
12-13-08, 12:38 AM   #5
Might want to take the spark plug out and just make sure the engine isn't flooded, or have oil residue built up in the cylinder causing hydrolock or excessive compression.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
