generator carb needed
Old 12-13-08, 11:41 PM
Ok acquired a used shop force 1000W 2 stroke generator. engine is a shop force 2.0HP 2 stroke. Im looking for the carb. according the manual that came with the generator its part number F01.06-00 however nothing comes up. any ideas. engine is model VE45F. all it says is shop force 2 stroke 2.0HP. no tecumseh or briggs etc. might not be able to get parts for it sense its shop force's own brand of engine.
Old 12-14-08, 06:17 AM
do you have the old carb ?
you might check the tecumseh two stroke carb used on the vertical crank post hole diggers and other equipment.
you know the HP so determine the bolt spacing and mounting configuration and check with some local repair shops. they likely have a couple laying around. the biggest problem you have is to make sure whatever you come up with does not run the engine lean.
Old 12-14-08, 02:50 PM
the engine runs on 50/1 mix.thats what it says on the tank. most 2 stroke carbs have adjustments. the carb is still on the machine. the part number is what the manual gave me. and im guessing the 2-stroke engine is shop forces own brand says it says shop force 2.0HP on the engine decal.
Old 12-14-08, 10:25 PM
cheese's Avatar
There's no engine brand of "shop force" to my knowledge. It sounds to me like a chinese generator. If so, good luck finding parts for it.
Is it a bowl or diaphragm type carb?
Old 12-15-08, 03:42 AM
is there a brand name on the carb ? the chinese tend to use mass produced carbs. if not, the carb may be a clone of a mass produced unit. as posted, if you have a carb have you had it looked at ? what it the problem you are having with the generator ?
Old 12-15-08, 01:06 PM
i thought it was a diaphragm type but that was just the fuel valve. i will have to pull it off and look.
heres a pic of the machine and the box. if it is Chinese i could pull the Chinese off and stick a American 2 stroke on it
Old 12-16-08, 03:22 AM
if you could snap a closeup of the carb someone might recognize it. you never said why you need one though. does the engine run ?
Old 12-16-08, 06:51 AM
30yearTech's Avatar
I have a small generator that looks just like your unit. It's a Chinese unit distributed by UST. The manual I have lists a number to call for parts and service, doesn't your manual list a number to call??
From digging around on the web, I have found references to Shop Force also being distributed by UST. I cannot find a website for UST, I believe they are the company importing the product and then labeling it for various companies to sell.
Old 12-16-08, 04:00 PM
OK its a float type carb. heres a pic of it. the engine does not want to start. If i put fuel into the sparkplug hole it will pop and maybe try to run but thats it. checked for spark and got a nice blue spark so its not getting fuel. i forgot how long the guy said it was sitting but he said the engine was always quitting. but he gave it to me for free sense he didn't want it.he said it would power a refrigerator.
Old 12-16-08, 05:17 PM
30yearTech's Avatar
My generator won't start if I let it set very long with fuel in it. I just drop the bowl and clean out the old oil residue with some spray cleaner and that usually takes care of it. You should just be able to clean out the carburetor, I doubt that you would need any parts.
Old 12-29-08, 03:44 PM
Check crankshaft sealf! They shrienk & pop out of the crankcase! Glue back in with super glue or opxy! The seal on the generator end can be inspected through the cooling slots in the crankcase! To test for loose seals----Spin over motor & check for vacum at mouth of carby! If nothing happening there it is a good indication seals are out sEEYA!wES! p/s I'm looking for a good carby.
