01-25-08, 10:27 AM
Sears Craftsman II 8 hp snowblower
Hi all,
I bought this snowblower a few years ago, used of course. The person I purchased it from after painting the machine and removed all badging. The only way I found out it was a craftsman was searching for it on the internet.
My problem is the main shaft that has a small cog and is attached to clutch has split in two. I need to call sears and order the part but dont know the model number. Can anyone tell me where it would be located?
The snowblower is working fine, it still throws snow, but because the shaft holding the clutch system has broken the chain connecting to the wheels does not operate anymore. But I can push it manually, and thats not fun
KY
01-25-08, 10:37 AM
The only way I can help is for you to look on the controls, cables, belts, etc for part numbers, I might be able to isolate the model number that way.
Fish
Fish
01-30-08, 05:58 PM
Hey Fish, I am having the same problem identifying the model number which has worn off of my machine.
it too is a Craftsman II, 8hp tecumseh, 24" cut
model number begins with either C93 or C83 and ends in 8-0
Serial # is SC0076605
part No for the lower cabinet (steel box that housse the drive assembly etc) is 308613
Part no for the friction wheel (rubber) carrier is 085501
part no for the friction wheel itself is 590574 (Tecumseh OEM part No)
part no for the plastic faring that sits on the handles through which the gear shifter sits is 306523
Any ideas?
thanks in advance. sorry for the post hijack.....
Any ideas?
AL
01-30-08, 09:50 PM
Don't know how mutch help this will be........BUT,
If it's a craftsman the model # will start with 536.xxxxxx.356 as a prefix tells them that it's a snow thrower,just like 143 means pushmower.And on all of the IPL's on snowblowers that I've looked at the name/model decal has been behind the augar on the top left.Or on a plate on top of the augar on the left side.(standing behind mechine).
NH
01-31-08, 04:37 PM
This snowblower is most likely an AYP or possibly Murray. Seems like every "Craftsman II" I have worked on is an AYP or Murray.
Here is a list of Craftsman model number pre-fixes & who makes them:
Craftsman Manufacturers
103..Roper
123..Yardman
131...American Yard Products
133...American Yard Product
143..Tecumesch
219..MTD
247..MTD
250..Case
271..Kiortz/Echo
278..Roper
291..American Yard Products
355..Roper
358.. Poulan//Weedeater
390..King-O-Lawn
500..Briggs &Stratton
502..Murray
517..Homelite/Jacobson
536...Murray
538..Murray
647..Roper
639..King-O-Lawn
835..Roper
854..White Farm Equipment
911..Roper
917..Roper
917..American Yard Products
988..Kubota
987..TroyBilt
991..Lawnboy
103..Roper
123..Yardman
143..Tecumesch
219..MTD
247..MTD
250..Case
271..Kiortz/Echo
278..Roper
355..Roper
390..King-O-Lawn
502..Murray
536...Murray
538..Murray
647..Roper
639..King-O-Lawn
835..Roper
911..Roper
917..Roper
988..Kubota
987..TroyBilt
991..Lawnboy
AL
01-31-08, 07:01 PM
oppps (stupit eyes,of fingers).In my previous post I failed to type the model prefix right the two times I tried.even I find it comfusing.It is suposed to be 536.xxxxxx.Sorry eveone. and going by indypower500 list,I think that means that murray makes snowblowers for craftsman.
OR
01-31-08, 08:27 PM
Friction Wheel Rubber
I have a 247. snow thrower but can't seem to find the p/n for just the rubber friction wheel. The whole assy (p/N 656-0012A) is $55 but all I need is the rubber. Any ideas?
CO
02-01-08, 08:43 AM
Yours is MTD
Posted By: admiral1381 I have a 247. snow thrower but can't seem to find the p/n for just the rubber friction wheel. The whole assy (p/N 656-0012A) is $55 but all I need is the rubber. Any ideas?Part number 656-0012A is the flywheel not the friction wheel assy. Part number 935-0243B is just the rubber friction wheel. MTD made your snow thrower.
AJ
CO
02-01-08, 08:47 AM
Part numbers
Posted By: Altimatic Hi all,
The snowblower is working fine, it still throws snow, but because the shaft holding the clutch system has broken the chain connecting to the wheels does not operate anymore. But I can push it manually, and thats not fun![]()
If you can post some pictures of the broken parts we can find the part numbers for you
AJ
12-14-08, 12:17 PM
Valve problems
Hi all,
I have a craftsman II, i bought it used last year and it worked great. We got out first snow fall yesterday, i used it for a few hours with no problems untill i ran out of gas. After filling it with gas i couldn't get it to start, upon pulling the plug i discoverd that i had no compression. I pulled the head off it this morning and found that the intake valve was stuck in the open postion. Does anyone have any sugestions what to do now? or maybe a drawing of this motor? is there a hatch or somthing that i can take off and see the camshaft? (without haveing to pull the motor and split the crank case?)
Thanx for your help
Chris
Thanx for your help
Chris
CO
12-14-08, 07:20 PM
Bad gas
Posted By: chris121277 Hi all,Chris you should have started a new post this is an engine problem not a snow thrower problem and would get more members looking at a new post. Your problem is old gas that has varnished the intake valve. You need to remove the heat box that covers the carburetor take pictures of the linkage and then remove the carburetor. Behind the carburetor is the breather it covers the valve box remove it and you have access to the valves. Compress the spring and remove the valve keeper pull out the valve clean off the varnish from the valve and the guide. Lube the valve reassemble.
Thanx for your help
Chris
AJ
