Way to save a boat load of money on V belts
Catamount's Avatar
12-15-08, 07:20 AM   #1
I was disgusted that Sears wanted $32.00 for a simple auger belt so I went looking for a cheaper solution.
I found this website AYP Belts Listing
which is basically a cross-reference based on your belt part number. It'll give you the corresponding belt size.
I brought the size to my local auto parts store and got a new belt for less than $5! And it works great!
30yearTech's Avatar
TX
12-15-08, 05:41 PM   #2
Standard automotive belts are not the same as fractional HP belts used on most outdoor power equipment. While they may work they may not last very long. Automotive belts are generally cut with different angles so they will not ride on the pulley's the same, and most OPE belts are Kevlar wrapped to give more tensile strength particularly for clutching applications. In some applications standard auto belts will work fine, but for clutching or load applications, I would recommend an original type belt.
cheese's Avatar
GA
12-16-08, 12:01 AM   #3
I agree. An automotive belt won't last very long in most riding mower applications.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
Catamount's Avatar
12-16-08, 05:32 AM   #4
Hmm ut oh. Although... I could go through 7 of these belts before paying for one OEM.
Will post back to this thread when the automotive belt kicks the bucket to update on how long it lasted.
indypower's Avatar
NH
12-16-08, 05:41 AM   #5
Automotive belts are not designed to take the stress that outdooor power equipment puts on them.
Last winter, we had "plowable" snow every 2-3 days from Jan thru the end of March. In late Jan, I had customer bring in his snowblower to find out why he kept breaking belts every week. He was buying automotive belts. I replaced them with the correct belts. He didn't break another belt.
And here in "snow country", you need your snowblower to do its job RIGHT NOW!!!
30yearTech's Avatar
TX
12-16-08, 05:51 AM   #6
Posted By: Catamount Hmm ut oh. Although... I could go through 7 of these belts before paying for one OEM.
If the belts last then that's great. If they need to be replaced often, then it's the amount of time it takes to replace the belt that makes the difference. If replacement can be done easily and very quickly, then perhaps the cheaper belts will be a good solution. If it take a long time and is difficult, then I would go with the more durable belt. Best of luck, I hope the cheaper belts work out for you.
indypower's Avatar
NH
12-16-08, 06:59 AM   #7
Big question: Is it worth the aggrevation of having to spend the time to change 1 or both belts every couple of snowstorms or even worse having to change belts when you are half way thru snowblowing?
Catamount's Avatar
12-16-08, 10:43 AM   #8
Good points guys! But since the belt is already on there, it is going to stay for now.
Thanks for the tip though, will buy the OEM belt next time.
