Honda EZ 5000 generator(how to seperate)
Old 12-16-08, 09:51 AM
How do I seperate the engine from the generator?
Old 12-16-08, 08:29 PM
cheese's Avatar
On most small generators, you have to open the generator case, remove the stator, and then remove the front housing from the engine. Why do you need to remove it?
Old 12-17-08, 08:20 AM
EZ 5000 generator
Originally Posted by cheese View Post
On most small generators, you have to open the generator case, remove the stator, and then remove the front housing from the engine.* Why do you need to remove it?
Because it has a bad engine, have removed generator field, armature is attached to engine shaft, fan interferes with last bolt in case, thanks phil
Old 12-17-08, 10:09 PM
cheese's Avatar
Is the armature bolt removed? If so, a sharp blow from the side on the armature with a 2X4 block of wood should pop the tapered-fit connection free at the crankshaft. Don't hit it so hard you bend the shaft, just pop it sharply from the side. Then the fan and armature should be out of the way.
Old 12-18-08, 07:48 AM
EZ 5000 generator
Is the armature bolt removed?* If so, a sharp blow from the side on the armature with a 2X4 block of wood should pop the tapered-fit connection free at the crankshaft.* Don't hit it so hard you bend the shaft, just pop it sharply from the side.* Then the fan and armature should be out of the way.
That worked thanks, I just did not want to break anything. Phil
Old 12-18-08, 09:28 PM
cheese's Avatar
Glad you got it! .
