Propane Conversion
Old 12-18-08, 08:41 AM
Propane Conversion
I purchased a used Dayton standby generator that runs on natural gas. I am looking for information on how to convert it to run on propane. It is a model # 3w056c with a Techumsa engine. Any help would be apprietiated.
Old 12-19-08, 03:47 AM
can't say without seeing the manual but it may be as simple as installing a restrictor in the fuel system or moving an adjustment. i couldn't find the manual online.
Old 12-19-08, 09:47 AM
bontai Joe's Avatar
Propane has more BTUs per cubic foot, so you need less fuel to generate the same energy. That's about all the help I can offer.
Old 12-31-08, 05:49 AM
Thanks for the imput. I will probable take the carb apart to see what adjustments I can make.
Old 01-01-09, 05:26 AM
most of the adjustments i've seen are made at the regulator or nearby. the generac standby's require only the removal of a restrictor in the regulator inlet to convert to NG. the restrictor is used for LP. after that, a little fine tuning of the regulator is all that's needed in most cases.
Old 01-05-09, 08:15 AM
The generator came with a regulator attached to the gas line. I am wondering if I should keep this and adjust it or just hook straight to the house propane line after the regulator.
Old 01-06-09, 03:50 AM
that regulator needs to stay. look for an adjustable valve at the inlet or base of the regulator. like i said, the newer units have a removable restrictor to go from LP to NG. the only safe way to do this without risking the unit is to aquire the installation manual.
