New owner operator needs advice.
Old 12-21-08, 02:26 PM
dogtag1968's Avatar
I'm experianceing my first winter in Spokane WA and it's going to be a white Christmas.
So I bought a used MTD 31AE150-062 snow blower, electric start (using ext. cord) easy pull rope starter, runs like new
The thing is that it dosen't throw the snow very far and the chute gets clogged. Now what I'm wondering is if that could be because the Auger rubber extensions need to be replaced. They do look pretty worn.
It has a 4.5hp engine and a 21" cut, I checked out my next door neighbors Craftsman 6hp B&S single stage and his throws snow @4times the distance mine does. Last yrs model.
Any advice is greatly appreciated.
Thanks
Old 12-21-08, 04:44 PM
Yep. sounds like you need new paddles (Auger rubber extensions). They do tend to wear out fast using them on asphalt or concrete.
Spray the chute & auger are with WD40 before each use and the snow will slide thru it easier and not clog. Also, make sure you are running it a FULL throttle when blowing.
Old 12-21-08, 05:25 PM
dogtag1968's Avatar
Thumbs up New owner operator needs advice.
Thanks indypower,I was really thinking that the paddles were going to be an issue. Looks like an easy repair and not that expensive @$80.00
I'll post when I've changed them out.And I'll give the WD40 a try.
Once again, thanks Beer 4U2
Old 12-23-08, 08:37 AM
dogtag1968's Avatar
I put on a new set of paddles, and the blower works like new. Don't even need WD40,couldn't be happier.
Thanks for your advice.
