Tecumseh HSSK55 Need To know where green wire from key goes
Old 12-22-08, 03:44 PM
I have a snow blower with HSSk 55 5 hp on it. I did a tune up on it and while removing the oil drain plug I accidently bumped the green wire that has two leads connected together. The one goes to the ignition key and I am not sure if the the other is a ground to the frame or what. Any help would be appreciated.
LH
Old 12-22-08, 04:56 PM
Green whire goes from the coil to the one side of the key, the other side goes to ground. When the key it removed it completes the ground shutting the coil off and the engine.
Or im wrong
Old 12-22-08, 05:18 PM
So I can ground it anywhere or is there somewhere specific? Would this wire not being grounded cause the blower to have no spark and not start?
Old 12-22-08, 05:26 PM
Usually it's screwed into a bracket into the left side of the motor, I suppose you could ground it anywhere but it was attached so it's a matter of finding where it went.
Depends on the manufacturer but usually no. Snowblowers engines usually have spark without the ground wire being attached, does your machine have a key? My NDN's toro needed to be grounded in order for spark to appear but it has a key and safety switches. I have a 10hp machine in the garage with no ground and it had spark but it is a points machine. Without knowing the model of your machine and engine it's hard to say for sure.
Old 12-22-08, 06:40 PM
It does have a key that you insert but don't have to turn. This model is a Tecumseh HSSK 55 Snow King on a MAck 520brand snowblower from Menards. I for certain have no spark.
