tecumseh governor not working
Old 12-22-08, 05:06 PM
T
I have an Ariens snowblower with a 7hp Tecumseh. The engine runs good, however, when a load is placed on it, the governor isn't adjusting the rpms. I watch the gov. lever and it doesn't move, I can move it by hand and alter the rpm. Any suggestions? This is a fairly old engine. Thanks
Old 12-22-08, 05:12 PM
C
What model of engine is it? Need more info
thanks
Old 12-22-08, 05:40 PM
T
Model # H70-130067
Serial # 937406234
Old 12-22-08, 05:52 PM
C
It has a mechanical governor, they rarely fail. Check the linkage and spring setup, the linkage may have loosened and moved which I have seen or you may have a missing or broken spring.
Here is a view of your engine, check 52 and 55.
http://www.landscapepower.com/pdf/Te...H70-130067.pdf
Old 12-23-08, 08:00 AM
T
checked the spring and linkage and everything is tight. While the engine is running, I'll engage the auger and the governor linkage doesn't move at all. I guess I would think that there should be some kind of movement if the problem was with the linkage or spring, I'm not sure, haven't messed with governors much.
Old 12-23-08, 08:53 AM
I
If the governor moves easily, my thought would be you may need a new spring.
C
