Craftsman Snowthrower auger bushing replacement
Old 12-23-08, 12:28 PM
I have a Craftsman 5 1/2 HP 24" Snowthrower, model no. 247.88255.1, and the bushings at the end of the auger shaft need to be replaced. I have removed the two bearing housings on each side and now need to pull the auger assembly out. The schematic in the manual shows a lock bolt on the back side of the auger pulley that apparently holds the gearbox shaft in the splined receiver. If I remove this bolt, will the auger assembly and impellor come out? If not, please help. We've got 12 more inches of snow coming...
Jerry Perryman
Old 12-23-08, 01:06 PM
I
You might want to read this thread. It may help. different make, same basic procedure.
http://forum.doityourself.com/outdoo...ulley-off.html
