blown tecumseh 9 hp snowking engine
deerefan's Avatar
12-24-08, 07:13 AM   #1
i have acquired a 2004 craftsman 9 hp 29 swath
snow thrower in like mint condition for dirt cheap
for the reason the owner over filled the crank case with oil and blew the engine (cracked the block)the other day
wondering what internal damage it might have besides the cracked block by over filling it with oil
and also wondering if i should replace the block
or savage the engine (removed good parts)and replace the whole thing but would have to be used
and is the crankshaft if good interchangeable with other models of 8 to 11 hp engines?
i,m going to remove the engine and tear it down next week
any thoughts on what i should do?
Airman's Avatar
TN
12-24-08, 07:47 AM   #2
You will need to disassemble the engine and determine damage to answer your questions.
Post blower and engine model numbers, etc. and maybe other questions can be answered.
indypower's Avatar
NH
12-24-08, 08:20 AM   #3
If the block is just cracked, you can have it welded depending on where it is cracked.
deerefan's Avatar
12-24-08, 09:27 AM   #4
i,m going to remove the engine over the weekend
and take it to my work bench in the basement and see where the cracks are but i tried pulling on the rope and it won't budge, the dip stick shows
oil a half an inch higher than the mark,so it's still holding oil and don't see any cracks so far
indypower's Avatar
NH
12-25-08, 01:42 PM   #5
try pouring some Marvel Mystery oil down the spark plug hole and let it sit overnight. Then pull off the recoil and put a socket on the nut that holds the cup and using a long handle breaker bar, try to break it loose.
deerefan's Avatar
12-25-08, 04:33 PM   #6
Posted By: indypower try pouring some Marvel Mystery oil down the spark plug hole and let it sit overnight. Then pull off the recoil and put a socket on the nut that holds the cup and using a long handle breaker bar, try to break it loose.
ok, will try that tomorrow
thanks, indypower
deerefan's Avatar
12-27-08, 07:50 AM   #7
i pulled the rope starter off and i could turn the crank both ways by hand,so it's not seize
there is a rattling noise when i turn the crank
and if i turn it clockwise looks like something inside catches on something and locks up till
i turn it counterclockwise again
indypower's Avatar
NH
12-27-08, 11:11 AM   #8
Sounds like you broke the rod.
deerefan's Avatar
12-27-08, 11:17 AM   #9
i didn' do it, bought it that way,
will i be better off just to replace the engine?
trouts2's Avatar
MA
12-27-08, 03:58 PM   #10
If it's a hairline crack that is not in a structural support area it can be clued with JB Weld or other quality high temperature glue for metal.
Drill stop the ends of the crack. If too narrow to get glue in drill along the length with a tiny drill that will permit loading the crack with glue. One the outside you can pile on a little more clue to dissapate some heat and hopefully add a small amount of strength.
I did this on a 5hp with a 2 inch hairline crack that formed a T at the top.
trouts2
deerefan's Avatar
12-28-08, 09:38 AM   #11
i removed the electric starter and don't see any cracks or holes in the block so far
i will tear down the engine next week
and see whats going on inside
have a happy new year
