Help To ID Replacement Carb
Old 01-02-09, 11:36 AM
Hi all - This is what I have from my Ariens/Tec Snowblower:
Model: 922024
Serial: 7223B
HS40-5544SE (found under electric start)
Any idea what my replacement carb # is??
Old 01-02-09, 11:48 AM
That engine number isn't in the parts lookup please recheck it and post the numbers that are on the carb.
AJ
Old 01-02-09, 12:08 PM
Model: 922024
Serial: 7223B
The only HS40-5544 with an E at the end is HS40-55440E
Carb Part #= Tecumseh 631794A (replaces 631907)
Carburetor
If not check your engine number again
Old 01-02-09, 05:38 PM
The number was rusted out, so that "8" could have been wrong. (I'll re-check it tomorrow) Also, here's a number off the carb: 5707F28. I hope this helps...
Old 01-03-09, 07:45 AM
T-carb
Your original carb is 631907 so cpgixxer guessed correctly. Carb kit is 31840.
AJ
Old 01-03-09, 04:21 PM
Thank you guys for the excellent help in identifying my carburetor. I'll be up and running by Tuesday. This site is too cool!!
