Honda Engine Stalling
dirtyd0944's Avatar
01-03-09, 07:34 PM   #1
I have 2 honda gx 200 engines used on go karts and the engines run good for about 15 minutes or so then the engines begin to stall. Sometimes the engines will crank back immediately and then sometimes they have to sit for a while before they will crank. Any ideas? I have read some threads and it looks like the carb could be causing the problem. Any particular cleaner I should use. Any ideas or advice is appreciated.
cpgixxer's Avatar
01-03-09, 07:47 PM   #2
Posted By: dirtyd0944 I have 2 honda gx 200 engines used on go karts and the engines run good for about 15 minutes or so then the engines begin to stall. Sometimes the engines will crank back immediately and then sometimes they have to sit for a while before they will crank. Any ideas? I have read some threads and it looks like the carb could be causing the problem. Any particular cleaner I should use. Any ideas or advice is appreciated.
When I redo carbs I take them to a small engine shop and get them cleaned in an ultrasonic cleaner, I swear by it. I've tried the soak in carb cleaner idea and it just doesn't get it as clean as the ultrasonic cleaner, plus carb cleaner can damage plastic parts if left in too long. Once you get it back sparkling clean put a carb kit in it, they should run like new.
Speedwrench's Avatar
OK
01-03-09, 08:54 PM   #3
sounds like your vent on the fuel tank is clogged and not alowing fuel to flow into the engines properly, or you have a fuel filter partially plugged. if the engines run good for a while you don't have a carb problem. the other possibility is the electronic ignition is getting hot and breaking down then working after cooling down.
Murphy was an optimist
cheese's Avatar
GA
01-04-09, 12:44 AM   #4
I agree with speedwrench. Sounds like either a venting or coil problem. When it dies and won't re-start, check for spark.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
dirtyd0944's Avatar
01-05-09, 11:06 AM   #5
Engine Stallling
The cars seem to be running better we think it was moisture getting in the tanks we put some heet fuel line antifreeze in the gas and so far no more problems. Thanks for all the advice if the problem returns we will try them.
