crankshaft bearing
Old 01-06-09, 08:04 PM
crankshaft bearing
hi there here is my problem i have a toro 8/24 and i was being cheap tried to match up a auger belt which was i bet to small so i finially went and got a proper one now when the auger is engadged is smell like rubber burning and gets real hot i think i did my crank shaft bearings in is there a way of changing them with out taking the motor a part or is there somthing else that could be wrong sorry about the spelling some help would be great thanks
Old 01-06-09, 10:13 PM
cheese's Avatar
Received 17 Votes on 15 Posts
I doubt there is any problem with the crankshaft bearing. I think you'll find that your new belt is burning. Check for proper routing, belt rubbing, seized pulleys, etc...
Old 01-07-09, 06:31 AM
make sure you did not put the belt over the brake. I have seen so many snowblower come in my shop where the owner replaced his belt and not knowing there is a brake, just installed the belt in the bottom half of the pulley and pulled it up to the upper pulley. With the brake being on the side of the pulley, the belt went over the brake instead of under the brake.
Old 01-08-09, 05:19 AM
i wll check all replys and post back what i find thanks for the help
