7hp Simplicity 755e Won't go in reverse Snowblower
Old 01-07-09, 06:48 AM
Seams to be stuck in 3rd gear won't go in the other gears or reverse any ideas?
Old 01-07-09, 07:27 AM
Stand it up in the front scoop. (drain the gas first). Disconnect the shift rod. Remove the bottom panel. Look over the shift mechanisms. Try to move it. You will probably find the shaft or other linkages are rusted. Spray with PB Blaster and work it free.
