Old 6hp tecumseh govner linkage HELP!
Old 01-07-09, 12:39 PM
Old old. Model number is h60-75003B
Old 01-07-09, 01:48 PM
Are you asking where the end of the spring goes?
Old 01-07-09, 08:06 PM
Yes, sorry should of clarified.
I tried that loop in the throttle linkage,
And I tried hooking it to the governor arm,
Old 01-07-09, 08:18 PM
I already tried to put it on the places where the arrows point
Old 01-08-09, 04:43 AM
It connects to the loop on the governor link right where it goes into throttle plate. 9top right arrow on your photo's). I would replace spring pN# 30826, yours looks a little stretched.
Old 01-08-09, 06:02 AM
I tried putting it there
And set at half throttle, It opens the plate up to WOT
It will go from a couple hundred rpms, to WOT
Old 01-08-09, 06:22 AM
Trust me, that is where it goes. I would suggest starting with a new spring as I suggested. yours looks like it is stretched and someone may have shortened it which would bring you to wot. If after a new spring you have the same problem i would look at throttle plate sticking or internal governor problem. Spring is less than $3, common part any local small engine shop that sells tec parts should have it.
Old 01-08-09, 10:00 AM
Oh yea I agree about replacing the spring
Would the throttle cable for slow/fast make it do this if its clamped in the wrong place, (lower right corner of pic)
Oh, and should the governor arm be able to move freely with the engine off?
Old 01-08-09, 10:35 AM
possibly, the picture shows throttle in slow/off position. connect cable and adjust sheathing so the control is at the slow position and tighten.
yes
Old 01-08-09, 01:21 PM
Well
I connected the new spring in the right places
the throttle is clamped where it should be
I must have some type of internal govorner problem..
Old 01-08-09, 02:22 PM
Did you by any chance mess with the governor arm? You may want to do a static adjustment before opening it up.
Here is a good link:
PER Notebook - Understanding Governors
