Drive chain from Noma snowblower keeps slipping off
Can anyone tell me why and what to do about it??
Thanks for any information you can give me.
Reason: chain is too loose.
Causes:
1). chain is "stretched" which is the term used for the wear of the chain links.
2). Bushings on the shafts are worn.
I would first check the bushing on the shafts that the chain is on. If these are worn(usually plastic and Noma went bankrupt in 2002 making your snowblower at least 6 years old) that would allow the 2 shafts to move around and taking the tension off the chain and causing it to slip off.
Causes:
Thanks Indypower,
I am sure you are right as there is quite a bit of slack on the chain. I will take a link out and hopefully that will work. If not I will have to look for a chain somewhere.
Yes, my Noma is 13 years old.
If it's just a worn chain, that can be found in almost any hardware store, because the size ranges are universal. Example: #50 chain is the same for all machines that use it, there really isn't a Honda #50 vs. a Toro #50.
Thanks for all the help.
The chain was "stretched" and we removed one link and were able to buy a half link and put that on.
Tried it yesterday and every thing seems to be just fine. Can't believe I'm anxious for a big snowfall so I can really test it out!
