engine model number
Old 01-11-09, 02:46 PM
engine model number
Im having trouble with my model number. its like rusted out were the first 2 numbers are. its a sears tecumseh engine and all i can make out is 143.XX032 i think its 143.X7032 but when i change numbers around the engines that come up are not electric start this is. I need a starter. the numbers off the electric starter are 6191 or i think 433298A its a 120 volt starter. the snowblower is model 536.918100. there both sears.
Old 01-11-09, 05:02 PM
I ran the model number of the machine, it's a 4hp tec , the only number I could cross is 143.607032 which is a HS40-55253B. Part # for the starter is Tecumseh # 33290E, 3 bolt starter -1 bolt on the top and 2 on the bottom.
Old 01-11-09, 05:05 PM
Actually a couple of other numbers crossed and they also used the same starter motor, they are all hs-40.
Old 01-11-09, 08:42 PM
30yearTech's Avatar
When I checked the model number of your snow blower, it shows that is came with a model 143.697032 engine. The starter shows to be the same as the one posted above # 33290E.
Sears shows it on their site for $152.00
Old 01-11-09, 11:17 PM
thanks. i believe the bearings in the starter are shot or going as the starter has trouble turning the engine and will lock up. i have to remove the starter and reset it by hand cause it won't turn. this time after i reset it and plugged it in without the engine it spun but i saw white smoke coming from the starter. and this was after 1 second. it didn't do it before.
Old 01-23-09, 05:04 AM
ok i ordered a brand new starter off of ebay. will let you know how it turns out when it gets here.
Old 02-01-09, 08:27 AM
ok got around to installing it. works great. no problem turning over the engine. replaced the oil and sparkplug while i was it. its been awhile.
