Generac 4000XL No Output
carlhunts4fun's Avatar
01-11-09, 06:57 PM   #1
I made the mistake last summer of starting my generator with a load applied{plugged into trailer}and the genertor stopped working. The engine starts and runs fine but has no AC output. Does anybody have any idea what may have failed? Was told it might be a failed voltage regulator...?
30yearTech's Avatar
TX
01-11-09, 07:26 PM   #2
Have you checked the circuit breakers?? Perhaps they just tripped and need to be reset.
01-11-09, 08:01 PM   #3
Yes all circuit breakers are in order,thanks for the reply
Airman's Avatar
TN
01-12-09, 06:30 AM   #4
Go to the link below and follow the procedure. You may get lucky is if loss of field magnatism is the problem.
Good luck
PER Notebook - Generator Field Flashing
01-12-09, 07:34 PM   #5
I tried the drill procedure and was unsuccessful. Still no output. I will order a new voltage regulator and let you folks know if that fixes it. Thands again for your response.
