1976 Ariens sno thro deluxe 8/32...
ewemule's Avatar
01-12-09, 08:46 AM   #1
Just broke the axle yesterday. At the point where the shaft goes through the differential. Who thinks a weld would work to get through the rest of winter ? So far, I found a new one for $105.00 not in stock.
Thank you,
Marty
indypower's Avatar
NH
01-12-09, 09:35 AM   #2
Please post the model number. looks like 932032.
ewemule's Avatar
01-12-09, 09:44 AM   #3
Model #...
924024 and the serial # 004393. It was purchased on 11-30-76 so it may not be a '76 model.
Marty
indypower's Avatar
NH
01-12-09, 02:08 PM   #4
I would think you could get it welded in a day or 2 & for less than $105.
ewemule's Avatar
01-12-09, 02:29 PM   #5
Latest plan....
Since it broke where the axle goes from 7/8" dia. to 1/2" dia., and right by the splines that engage the differential, it doesn't look like a decent weld spot. We're going to take a piece of 1/2" steel rod which is longer than that which broke off, bore a hole into the 7/8" part and stick 'er in. Pin it and maybe a couple small spot welds if they'll not interfere with the splines. Sounds good and we should know in about 3 days. Nearby ski area has a priority part in for a fix. Still keeping an eye out for a used axle. Never know.
Marty
