need some help
Old 01-20-09, 05:17 AM
need some help
hello i got a 5.5hp rototiller that i forgot outside in the snow i just brought it in but when i pull the cord its stuck is my engine seized? its a honda engine thanks
Old 01-20-09, 05:21 AM
Engine should not be seized from being outside, recoil most likely frozen (from cold + ice) either bring into warm space or remove recoil and check.
Old 01-20-09, 08:39 AM
bontai Joe's Avatar
Recoil is either frozen or your carb leaks and fuel made it thru the carb into the cylinder and has hydrolocked your motor. Sounds scary, but all that means is the space above your piston may be filled with fuel and it's impossible to compress a liquid, so remove the spark plug and try pulling on the starter easy (no cigarettes!). If hydrolocked, fuel will spit out the spark plug hole. Once you get the fuel out and replace the spark plug, it should start
Old 01-20-09, 09:48 AM
thanks alot guys good thing its a easy fix thanks again
Old 01-21-09, 07:24 AM
bontai Joe's Avatar
Let us know how you make out.
Trackbacks are On
Pingbacks are On
Refbacks are On
