Toro 824 10 hp snowblower help
Old 01-21-09, 04:30 AM
E
Hello all i need some help with my blower, the motor turns on and runs great but the auger is not spinning! Could it be the gear box and if it is does anyone know a good spot for parts?? Thanks for any help..
Old 01-21-09, 04:51 AM
T
The issue could be a number of things. What is the model and serial numbers off the back base of your machine?
What have you checked so far?
Broken or loose belt.
Auger blades bolted to the auger axle or spin freely.
Can you turn the impeller by hand and with the other hand feel the auger blades move.
Stand the machine on it's bucket, take the skid plate off and look inside.
david Buying a Snowblower
Old 01-21-09, 05:54 AM
I
Most common failures are:
1). shear pins in the auger are sheared. They look like bolts.
If this is the case, DO NOT use any ole bolt. Get the correct shear pin. Shear pins are soft and are made to break.
Using a standard bolt, the bolt will not break and will cause the gears insdie to break and/or strip.
Shear pins: $2.00 each. Gears:$50 plus labor.
2). broken belt. Check it by removing the cover that is located in front of the engine.
Old 01-21-09, 01:46 PM
E
Toro 824 auger not spinning help..
Thanks for replying guys..
The Model #38080 Ser. #9003079 and its 10 horsepower.
The belts are good
I will check the shear pins to see if they are broken
Thanks again
Old 01-23-09, 04:28 PM
E
Thanks for the help guys.. I took apart the gear box and of course the worm gear is shredded. I also noticed that the box was dry meaning that the oil leaked out causing the gears to shred. Thanks again
