Craftmans snow thrower
Old 01-28-09, 04:37 PM
I have a 2 year old craftman snow thrower model #15A114 - 0342 8.5HP It ran good the first few times I used it. Now when I put it under a load it will die out and have to wait 15 to 20 minutes to restart it and then it might run for 5 to 10 minutes. I put a new carb. on and it ran good for a while then started to what it did before. Could it be the gas cap or coil thats causing the problem
Old 01-28-09, 04:49 PM
Yep. could be either. Run it with the gas cap loose(tighten it, then back off half a turn). If it runs longer, then the vent is blocked. If not, sounds like the coil is heating up and you need to replace the coil.
