Mtd snowflite model 319-800a
Old 01-31-09, 05:11 PM
I have a mtd snoeflite snow blower older model 319-800a a part came lose distroyed the solide state module the part no 1830545 is no longer avalible if i can get a used part it will be grate the motor is in good shape i don't wont to throw it away. Any help please
Old 01-31-09, 05:25 PM
Post the model number, etc. from the engine.
Old 01-31-09, 05:35 PM
The number 319-800a-k068b is on a tag on the case below the rear of the engine i can't find a no on the engine
Old 02-01-09, 10:08 AM
Engine or Machine
Where does this solid state module go?
AJ
Old 02-01-09, 09:19 PM
AJ the module go's right behind the flywheel.Internal igntion also caller magneto ignition system
Old 02-02-09, 10:33 AM
It's the engine
Than you will need to find & post the engine numbers. Look for them stamped into the blower housing/rewind housing up by the spark plug.
AJ
Old 02-03-09, 10:25 AM
aj I find the numbers on the pull cord HM80 155127E SER 8283D I HOPE THESE ARE THE ONES
Old 02-03-09, 01:23 PM
Tecumseh
Those are your engine numbers go to this link it is a break down of your ignition system it is not sold state but a points & condenser magneto. What parts do you need?
Parts and Diagrams for Tecumseh MG-610694A
Old 02-03-09, 03:42 PM
Thanks aj it is alot of help they have most of the parts I need.Condenser,contact assy.coil assy,coil locking clip.when I get the parts I'll let you how it go's Agan thanks
