Ariens 924048 belt tensioner spring
Old 02-05-09, 05:54 AM
The spring attached to the belt tensioner on my Ariens has broken. I have the replacement, but having trouble installing the new spring. Very hard to reach location. This is the belt that drives the wheels. It appears I need to remove the main pulley, this has also been a challenge as the locknut seems to be frozen. Does anyone one have any suggestions? Thanks.
Old 02-05-09, 11:25 AM
remove the auger assembly and the bottom panel and you should have easy access
Old 02-07-09, 03:22 PM
Ariens 924048 tensioner spring
Thanks - I can see where the spring attaches to the tensioner arm now. However, I can not see where the other end attaches. There is a smaller spring that engages the blower attachment, that is attached in the frame, but it does not appear the spring I am trying to replace goes there as well. Appreciate your help. I do have a picture, not sure if I can upload it here.
Old 02-08-09, 08:27 AM
There should be a hole the size of a quarter just above axle bearing, the end of the spring simple goes in there. Yes it is easier to remove drive pulley, an impact wrench works best if you do not have improvise. Get a box wrench on the nut and hit wrench with rubber mallot, it should free right up. I imagine you have already hit with some penetrating oil, if not do so.
Old 02-08-09, 04:35 PM
I did manage to get the pulley off and now see where the springs goes above the axle. Thanks for your help.
