Metal in B&S carb ?
Old 02-05-09, 11:39 AM
Metal in B&S carb ?
Hi.
Does anyody know what type of metal my carb is made of?
Sinc cast or alu cast?
i have a 1980 10hp snowblower engine 190402 with a crack in the carb housing, and want to solder it.
Are there any ways to surfacetreat it eg. anodizing?
Thanks
Old 02-05-09, 12:19 PM
Most all carburetor bodies are aluminum. You do not say if something is broken loose or if there is just a crack in the metal. I would think a product like JB Weld would work. Clean the area well with MEK, Acetone or alcohol before repair.
The heat required to solder would probably cause damage.
