Murray Riding mower slows down when turning
Old 02-08-09, 05:25 AM
B
My murray riding mower has recently started making winding sounds and struggling to get up hill or when i turn while cutting the grass. The blades and mower will slow down and when i straighten back out from a turn the blades and mower seem to go back to normal. The blades when I am going up a hill or turning almost come to a complete stop but when I am back at the top of a hill or finished turning the blades and mower pick back up to normal speed. Not a very handy mechanic type, so any suggestions would be greatly appreciated!!
Old 02-08-09, 05:59 AM
I
Does this have electric clutch for the blade engagement?
Old 02-08-09, 11:44 AM
B
It has a lever on the right hand side that you push forward to engage the blades and pull back to disengage them. Sorry, not even a novice when it comes to mechanical stuff.
Old 02-08-09, 11:51 AM
G
You sure this is a Murray ?? what you describe sounds like an MTD.
Old 02-08-09, 03:13 PM
B
Yes it is a Murray. I believe it is the motion drive belt, the mower will start fine and sounds great, but will not even move forward or in reverse when you press the gas pedal forward or press the reverse pedal backwards for reverse. The belt I can feel and see and it has a ton of play in it and looks to be worn in some places and also feels to be maybe off line form its regular position, but not familiar with what the actual correct feel or look to that position is. Is this something easily looked at and replaced or fixed??
Old 02-08-09, 03:57 PM
I
Please post the model number.
Old 02-08-09, 05:33 PM
G
ok, you must have one of the old Murray wide bodys that has the Peerless VST 2nn hydro.
won't know until you post the model number.
thanks,
Old 02-08-09, 05:52 PM
B
Sorry for the delay, the model number is 42598x92a
I believe this is a 1999 model or maybe a 1998. Thanks!!
