Kohler fuel pump
Old 02-08-09, 12:44 PM
Kohler fuel pump
I bought a 10yo Craftsman 42 917.271012 w kohler 15.5 cv15s 41464
I noticed a oil drool coming from the fuel pump. I checked the parts diagram and found on evidence of a fuel pump spacer on the motor.
I ordered the o ring, spacer and gasket.
My fuel pump 12 393 05 h7 has no grove for the o ring
just flat plastic and it looks like it only had a gasket between the motor and fuel pump.
The fuel pump arm has 2 wear marks on the arm. 1 in the factory dip or notch and the second closer to the pump body.
The question is do I get a second gasket and install the spacer plate w/o o ring.
Or get a fuel pump?
thanks
Marvis
Old 02-08-09, 03:43 PM
oops Kohler fuel pump
12 393 02 h7
My fuel pump 12 393 02 h7 has no grove for the o ring
Or get a fuel pump?
thanks
Marvis
Old 02-08-09, 04:43 PM
ooops
cv15s 41564
Or get a fuel pump?
thanks
Marvis
Old 02-08-09, 05:13 PM
cheese's Avatar
Sounds like someone has done something to this....
2 wear marks makes me think someone robbed this pump off a different engine and put it on this one. I think if you want it to be right, install the correct pump as shown in the diagram. It might work if you used the existing one with new gaskets, but without knowing what engine the pump came from... who knows....
Old 02-08-09, 08:05 PM
kohler fuel pump
I was afraid you would say that.
2 wear marks and no grove for o ring, this fuel pump had to come from a different motor.
I found reference to 12 393 03 ( one of the pumps that interchange) but not 12 393 02 h7?
The point is fix it right and i may never have to touch it again.
That is why i pull the shrouds and cleaned the grass and gunk out of the cooling fins. Drilling and tapping shroud bolt holes. Epoxy and rivnut the top cover bolt holes that had been drilled and drilled.
Its not a new mower but it works well and getting better!
Marvis
