Honda EX650
Ruckryder's Avatar
02-10-09, 12:28 PM   #1
Honda EX650
I'm working on a friends generator , history is as he tells it only 20 hours before he let it sit for a year . I removed and cleaned the fuel tank , disassembled the carb and cleaned it all out . Now I've found there is no cylinder compression at all . Is it possible the valves or rings are gummed up ? Should I do a leakdown test ?
Airman's Avatar
TN
02-10-09, 07:01 PM   #2
It is possible something is gummed and stuck. If you have a leakdown tester do the test. It will tell you where the compression loss is.
cheese's Avatar
GA
02-10-09, 08:02 PM   #3
Have you pulled the valve cover to see if a valve is stuck? A leakdown test will show you if this is the case but I think you're gonna have to pull the valve cover anyway, even if it's not the valves sticking...so pull it and see.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
Ruckryder's Avatar
02-12-09, 09:50 PM   #4
I pulled the head off and found the intake valve stuck open . I soaked the valve with carb cleaner and let sit for awhile and finally got it loose .
cheese's Avatar
GA
02-13-09, 10:34 PM   #5
Good job. Thanks for the update!
God bless!
Ruckryder's Avatar
02-16-09, 08:47 PM   #6
Well I installed the new headgasket , torqued the head . It starts first pull every time . I warmed it up and changed the oil and ran it for 15 minutes , set the carb , no leaks ! Done deal . Great site you have here , I'll be spending more time here in the future . Thanks .Beer 4U2
